In Tree Tech Revision 3.1 received "Error in FCSINIT - Use the TaskBar to find its window and check the error".
  • In Tree Tech Revision 3.1 received "Error in FCSINIT - Use the TaskBar to find its window and check the error".
  • SESA113595
    SESA113595
‎2018-09-06 01:56 PM
In Tree Tech Revision 3.1,  received  "Error in FCSINIT - Use the TaskBar to find its window and check the error".
TAC I/A Series Tree Tech, Revision 3.1
TreeTech 3.1 will only function with communication ports 1 through 9.
Ports above 9 result in "Error in FCSINIT - Use the TaskBar to find its window and check the error".
Select a communications port in the valid range from 1 through 9.
  • TAC IA Series
  • 4955
