In Tree Tech 3.1, when starting communications, a failure occurs preventing proper initialization of communication sub-subsystems: "Windows cannot find 'CDECHICO.EXE'
  • In Tree Tech 3.1, when starting communications, a failure occurs preventing proper initialization of communication sub-subsys...
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 01:43 PM
When starting communications, a failure occurs generating the errors illustrated below:
Windows cannot find 'CDECHICO.EXE'.  make sure you typed the name correctly, and then try again.  To search for a file, click the Start button, and then click Search.
Tree Tech 3.1
The "Connection Type" for a network in the E: EQUIPMENT DATABASE was assigned as "ARTIC ECHELON".
This connection type was used for a communication interface card that was obsoleted many years ago.  It was used with IBM's motherboards using MicroChannel expansion sockets.
Click on the down-arrow and select a different connection type.  The two most-common are:  Ethernet and Serial.
  • TAC IA Series
  • 5470
