In TAC Menta, it is not possible to define the TAC Xenta System Version to the latest versions
  • In TAC Menta, it is not possible to define the TAC Xenta System Version to the latest versions
  • MikaelKrantz
    MikaelKrantz
‎2018-09-06 02:17 PM
In TAC Menta, under Device Specification, it is not possible to  define the actual System Version or Hardware version of your TAC Xenta device.
TAC Menta Version 5.1.5
TAC Xenta 280/300/401 Version 3.80, 3.84
When a new System Program for TAC Xenta devices is released, TAC Menta is not always updated with the latest TAC Xenta version number.
Until the correct TAC Xenta System Version number are available in the TAC Menta, you could use the closest lower version number.
  • 4320
