In OPRIF 11.6, the "database save" command does not work.
  • In OPRIF 11.6, the "database save" command does not work.
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-06 11:13 AM
In OPRIF 11.6, the "database save" command does not work.  When pressing "S" for save, the first prompt asks for the drive letter where the files will be saved (i.e. C drive).  After pressing enter, the second prompt requests a filename.  An eight-digit filename can be entered.  A file path is optional.  After pressing enter, a new screen should appear as the database save begins.
However, after pressing enter, the screen returns to the main database menu.
There are no errors reported.
DMS
OPRIF 11.x
A graphic screen is missing from the installation of OPRIF.  After entering the driver letter and filename for the database save, a new screen should appear.  The graphic file is requested but doesn't exist.  As a result, the database save command aborts and returns to the main database menu screen.
The simplest solution is to re-install OPRIF 11.6 "overtop" the existing installation.  The missing file(s) will install.
  • TAC IA Series
  • 10901
