In Niagara G3, the SNMP driver reference manual refers to three MIB files required so that the SNMP Point Manager can "discover" and "add" SNMP points as need...
  • In Niagara G3, the SNMP driver reference manual refers to three MIB files required so that the SNMP Point Manager can "discov...
‎2018-09-10 11:13 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:05 AM
In Niagara G3, the SNMP driver reference manual refers to three MIB files required so that the SNMP Point Manager can "discover" and "add" SNMP points as needed.  The filenames are:
TridiumR3-MIB.my
RFC1155-SMI.mib
RFC1213-MIB.mib
Where can they be found?
Niagara G3
The three files are not easily located.
The TridiumR3-MIB.my file is installed with the version of Niagara G3 installed on the host computer.
The other two files (RFC1155-SMI.mib & RFC1213-MIB.mib) can be found on the World Wide Web by searching using their specific filenames.
All three files are available here:  SNMP_Files_for_G3
  • TAC IA Series
SNMP Files for G3.zip
  • 8054
0% helpful (0/1)
