In MNB-1000 (Plant Controller) firmware Revision 1.50E, the Spanning Tree Protocol is Disabled, by default.
  • In MNB-1000 (Plant Controller) firmware Revision 1.50E, the Spanning Tree Protocol is Disabled, by default.
‎2018-09-07 02:32 PM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:55 AM
All previous versions were shipped with the Spanning Tree Protocol enabled.
TAC IA Series
I/A Series MNB-1000 (Plant Controller), firmware Revision 1.50E, and later.
In some cases where multiple BACnet routers (eg, MNB-1000, UNC, ENC, etc) were installed on the same BACnet-IP internetwork, having the Spanning Tree Protocol enabled in the MNB-1000 would allow a "router loop".
Be aware that in MNB-1000s with firmware Revision 1.50E and later, the Spanning Tree protocol is disabled, by default.
Click here to see the Release Notes for firmware Revision 1.50E .
It is always recommended the highest firmware version available for the MNB-1000 be used.  Many issues have been addressed for better functionality.
  • TAC IA Series
Tags (2)
  • 4942
  • RandyDavis23
