In I/NET 2.13, cannot access NP Routers, when Link Type is equal to Netplus Router (NPR)
  • In I/NET 2.13, cannot access NP Routers, when Link Type is equal to Netplus Router (NPR)
  • sesa139513
    sesa139513
‎2018-09-06 02:59 PM
I/NET Site
I/NET 2.13 site and cannot access NP Routers
As a workaround...
  1. Edit the configuration profile
  2. Choose None, or Direct Link, enable TCPIP, then close the window.
  3. Restart I/NET (close I/NET and I/O Server, re-open)
  4. Go back to I/NET Configuration.
  5. Click modify and then should be able to access the NP Routers button. (You need to do this every time you need to access the Netplus Router directly.)
  • TAC INET
  • 2544
