Improper object references appearing in Occupancy Point field of Infinity Schedule object in Continuum 1.74.
  • Improper object references appearing in Occupancy Point field of Infinity Schedule object in Continuum 1.74.
‎2018-09-06 11:11 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:48 AM
An Infinity Program object appears In the Occupancy Point field of the schedule editor.
When an attempt is made to browse, select apply the proper occupancy numeric, the same Infinity Program object reference reappears.
  • Continuum 1.74
  • Schedules
  • Occupancy Point
  • Database
This behavior was related to the behavior described in TPA-BOST-08-0005.00.
Apply the Cyber 1.74 SP2 HotFix For TPA-BOST-08-0005.00.
  • 11234
