Import file not found warning when loading SNMP MIB files provided by SE into NMS tool
  • Import file not found warning when loading SNMP MIB files provided by SE into NMS tool
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
Captain AbeMeran Captain
‎2020-01-31 11:44 AM
on ‎2020-01-31 11:44 AM
Receiving warnings such as Import[SNMPv2-CONF] not found for mib [ACC-NC-ALARM-MIB] when loading EBO/Continuum MIB files into SNMP NSM tool
EcoStruxure Building Operation, Andover Continuum
  • Continuum NetController II
Required base MIB files referenced in the IMPORT section of the EBO/Continuum MIB files not present
The EBO/Continuum MIB files contain references on their IMPORT section to base MIB files that are commonly included with the SNMP tool used to compile the MIBs. (See screenshot below)
Those files are typically included/installed by the SNMP NMS tool, in cases where the tool does not include the base files they must be located and either loaded manually before loading the EBO/Continuum MIB or placed at the appropriate folder for the tool being used.
For example, when using MG-SOFT SNMP MIB browser, the tool places the base MIB files @ C:\Program Data\MG-SOFT\SMI Modules\MIB Modules\SMI
Labels (2)
  • AbeMeran20
