If there is a routing problem with a MNB-1000, how can the routing table be cleared?
  • If there is a routing problem with a MNB-1000, how can the routing table be cleared?
  • sesa119747
    sesa119747
‎2018-09-06 02:56 PM
MNB-1000
The MNB-1000 controller need to relearn the network information.
Anytime there is a routing loop or a network mis-configuration on a BACnet internetwork containing MNB-1000 controllers, it is possible to get a network mismatch displayed in the status column of the WorkPlace Commissioning tool.
Because the MNB-1000 controller has learned the mis-configured network information, its routing tables will have incorrect information. Currently, the only way to remove this information and fix the problem is to correct the network mis-configuration and reboot the MNB-1000. Upon restarting the MNB-1000 controller, if the problem still exists the network mismatch will still appear in the status column, indicating that the problem is not resolved. If the problem is resolved this message will not display.
  • TAC IA Series
  • 2706
