If there are multiple TAC Vista Servers is multiple TAC Vista SmartStruxure Interfaces needed?
  • If there are multiple TAC Vista Servers is multiple TAC Vista SmartStruxure Interfaces needed?
  • sesa150555
    sesa150555
‎2018-09-06 09:47 AM
In a TAC Vista server Network is a TAC Vista SmartStruxure Interfaces needed for each server?
TAC Vista Server 5.1.8 or later
SmartStruxure
Do I need to set up a TAC Vista SmartStruxure Interface per TAC Vista server or can I use just one for all Servers?
You don't have to set up an TAC Vista SmartStruxure Interface per server but you can have several if you want to reduce the server to server traffic.
Labels (2)
  • 15293
