If a controller is not being used for 06 emulation, does the Boot ROM revision need to be the same as the host revision?
  • If a controller is not being used for 06 emulation, does the Boot ROM revision need to be the same as the host revision?
‎2018-09-06 03:13 PM
I/NET site
06 Emulation
No. Only needs to be the same when 06 emulation is being used.
  • TAC INET
  • 1674
