ID Works Setup with TAC I/NET 2.4X and Windows 7 64-bit
  • ID Works Setup with TAC I/NET 2.4X and Windows 7 64-bit
  • Tom_Poovey
    Tom_Poovey
‎2018-09-11 07:29 AM
How to set up ID Works 6.5 in Windows 7 64-bit.
TAC INET
  • ID Works version 6.5
  • I/Net Seven rev 2.4X
  • SQL2008 R2 (Full)
  • SQL2008 R2 Express
Normally this is needed for an upgrade or a new install of ID Works and I/Net Seven on a new Windows 7 64-bit PC.
See ID Works Win7 64-bit Setup.pdf for step by step instructions for setup.
  • TAC INET
Tags (3)
  • 16025
  • Datacard
  • ID Works
