I2/b3 controller issue using PE functions Minimum, Maximum, Average etc with only one argument.
  • I2/b3 controller issue using PE functions Minimum, Maximum, Average etc with only one argument.
  • AbeMeran
    AbeMeran
‎2018-09-06 01:02 PM
Using PE functions designed to take multiple arguments (Minimum, Maximum, Average) with just one argument causes undesired behavior.
CyberStation
i2 devices
b3 devices
Functions expecting more than one argument require that more than one argument is passed.
Make sure to always pass at least two arguments to PE functions that are designed to take multiple arguments such as Minimum, Maximum, Average etc
For example:
OAT = Minimum(MyNetwork\MyCX\Myi2Device)
The line above may cause undesired controller behavior
Replace the line above with the following line
OAT = MyNetwork\MyCX\Myi2Device
  • 6657
