I need an object in the UNC that works like the Select object in WorkPlace Tech.
  • I need an object in the UNC that works like the Select object in WorkPlace Tech.
  • Kim_Baze
    Kim_Baze
‎2018-09-06 12:57 PM
I/A Series R2 (Niagara) UNC
Specified logic requirements for the UNC station require it.
Inside the TridiumX container - programlib jar - hvac container there is an object called AiMapping that will perform a select function similar to that of the object provided with WorkPlace Tech.
  • TAC IA Series
  • 6815
