I controlled a point on an MR (or ASC) but the point value went right back to what it was before I controlled it. Why?
  • I controlled a point on an MR (or ASC) but the point value went right back to what it was before I controlled it. Why?
‎2018-09-06 03:23 PM
I/NET MR or ASC
Quick polls are probably turned off.
  1. Select Edit, Controller, MCU Config.
  2. Once that's up select Stationx, where x is the address of the port that MR, etc is connected to.
  3. Find the MR\ASC\etc. and make sure the box in the "QP" column is selected.
  • TAC INET
  • 1248
