I/NET - Temporary Individual download problem
  • I/NET - Temporary Individual download problem
‎2018-09-07 06:32 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:48 AM
I/Net Seven using Access Control with at least one host pc for making badges or used for Access Control editing.
Download of changes to Access cards or Individual information not getting to the controller right away.
If you add a card to the system and want it to be temporary be sure to check the "Automatic DPU restore" under Edit - Network configuration choose modify the Link. Choose what Host that should handle the request. Listing more than one Host address will increase network traffic and burden the network. I suggest you put a single Badging Machine or Host for Restore host 1. This can be read about in TCON300 under page 5-10.
  • TAC INET
  • 3946
