I/NET Site Inventory and best practices
  • I/NET Site Inventory and best practices
  • Chris_Asbury
    Chris_Asbury
  • sesa139513
    sesa139513
‎2018-09-10 11:26 PM
Inventory and Serial Numbers for each of the Host Computers
TAC INET
I/NET sites or Multiple I/NET sites under your responsibility
Desire to be organized and have site information quickly available
The easiest way to collect the Serial Number and Version is from Help > About INET.
Request a screen capture of each workstation with I/NET installed. This will give you the exact release, build, User/Site names and the serial number.
Below is the splash screen which is seen when I/NET is opened:
Then organize in a spreadsheet or folder structure which is kept up to date with any changes in the field.
The trick is to have the correct screen capture from the correct computer. Designating as a File Master, Equalized Client, Remote Client, or Stand Alone would also be beneficial to have. Host Number for each Host Computer and a Static IP address would be excellent to keep in the spreadsheet.
  • TAC INET
Tags (2)
  • 12315
  • INet Serial Numbers
