I/NET Seven fails to install with existing MSDE version of SQL.
  • I/NET Seven fails to install with existing MSDE version of SQL.
‎2018-09-06 02:47 PM
I/NET
MSDE
Windows XP
MSDE may need to be installed manually
  1. Download MSDE2000 from Microsoft’s website.
  2. Run the downloaded program, and it extracts itself into another directory.
  3. At that directory, run drive:\directory its located in\Setup.exe SAPWD=”any password you make up”
  4. After the MSDE is installed, run the I/NET installation as usual.
  • TAC INET
  • 3083
