I/NET Seven Advanced Communication Settings
  • I/NET Seven Advanced Communication Settings
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 01:16 AM
Advanced Communication Settings Video
TAC INET
I/NET Seven rev 2.13 and above
Video tutorial for Advanced Communications in I/NET Seven rev 2.13 and above.
[video]
This video is about advanced communication settings using I/NET Seven rev 2.13 and above. I/NET now allows you to define which communication port the NPR2000 or Xenta 527-NPR will use. You can also enable communication encryption and set up IP filters.
  • TAC INET
  • 3001
