I/NET Host Tool Initialization Error saying this version of I/NET is unregistered
  • I/NET Host Tool Initialization Error saying this version of I/NET is unregistered
‎2018-09-07 02:34 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:47 AM
TAC INET, TAC Vista
  • I/NET
  • Vista 5.1.5
Vista and licensing must be installed before I/NET host tool
Ensure that you are installing I/NET Host Tool and not a full copy of I/NET.  If you wish to run a full version of I/NET you will need to purchase that as a separate license. The In House Engineering Dongle does not include a license for I/NET host tool.
Download I/NET Host Tool
The I/NET Host Tool is also included a separate executable on the I/NET CD
Uninstall I/NET Host Tool
  1. Go to Control Panel > Add & Remove Programs
  2. Remove I/NET Seven
  3. Remove Microsoft SQL Desk Top Engine (MSDE)
  4. Go to Windows Explorer > Program Files
  5. Delete any remaining I/NET Seven files and any remaining MS SQL files
Re-install I/NET Host tool
  1. Ensure that the Vista License Server is running
  2. Extract the installation files from the .zip file
  3. Run setup.exe
  4. If you are using a Dongle or a Vista License that does not include I/NET host tool you will be prompted for License Key that must be purchased. If you believe you have received this prompt in error, contact Product Support.
Labels (2)
  • TAC INET
  • 4989
