I/NET 7716 emulating a 78061 Tap
  • I/NET 7716 emulating a 78061 Tap
‎2018-09-07 09:07 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:47 AM
Can a 7716 emulate a 78061 Tap?
TAC INET
I/NET site
This emulated Tap requires the use of an optional RS232 expansion module. Using this Tap function, you can connect a Hayes compatible modem to port P2 of the RS232 expansion module. You may then configure the modem for auto-dial/auto-answer (AD/AA) operation.
A 7716 can emulate a 78061 Tap.
Using the Hand Held Console (HHC):
  1. Press [Code], 90, [Enter]
  2. The emulated device type model number displays in the read out
  3. Press [Inc] or [Dec] to toggle through 7801, 7803, or 7806 Tap emulation
  4. Press [enter] to accept your choice
  5. You will need the RS-232 expansion card for ADAA
See TCON 096 for details.
  • TAC INET
  • 1482
