I/NET 2000 1.XX Reporter "Active X" error message
  • I/NET 2000 1.XX Reporter "Active X" error message
‎2018-09-06 03:27 PM
Exporting files works fine from I/NET 2000 1.XX, but when Reporter is making a report, an  "Active X" error message is displayed.
I/NET 2000
The ODBC driver or its toolbars has been corrupted.
  1. In the PC's registry, delete the toolbars and restart Exporter / Reporter.
  2. If this does not fix the problem then re-install the ODBC driver. If you are running an I2K rev 2.xx you have to re-install I2K too.
    WARNING: Modifying the registry can damage the operation of the workstation if done incorrectly.
  • TAC INET
  • 1078
