I/A Series G3 Niagara network points in fault and indicate Subscribed error:invalid permissions.
  • I/A Series G3 Niagara network points in fault and indicate Subscribed error:invalid permissions.
  • WaynePeters
    WaynePeters
‎2018-09-06 09:49 AM
I/A Series G3 (all versions)
The credentials being used by the connection does not have the correct permissions to access the data.
Verify username / password and associated permissions related to station to station fox connections.  Modify the associated permissions on the server side or use another set of credentials that have permissions.
  • TAC IA Series
  • 15178
67% helpful (2/3)
