I/A Series G3 (Niagara) ERROR [Current Date ] [AsdNetwork_COM3] Unlicensed: /Drivers/AsdNetwork Javax.baja.license.FeatureNotLicensedException: tac_llc:tacasd
  • I/A Series G3 (Niagara) ERROR [Current Date ] [AsdNetwork_COM3] Unlicensed: /Drivers/AsdNetwork Javax.baja.license.FeatureNot...
  • Kim_Baze
    Kim_Baze
  • Julio_Cortes
    Julio_Cortes
‎2018-09-06 01:58 PM
ERROR [Current Date] [AsdNetwork_COM3] Unlicensed: /Drivers/AsdNetwork
Asd Driver
The issue is caused by a missing certificate. Each license installed needs to have a matching certificate.
  1. Obtain TAC_LLC Certificate
  2. Install under License Manager
  3. Reboot ENC
If issue persists verify the license file name is correct, i.e. TAC_LLC.license.   If it doesn't match this name exactly obtain new license file.
  • TAC IA Series
  • 4993
