I/A Series G3 Enterprise Network Server (ENS) learned proxy point does not properly inherit the maximum override duration facet setting configured for the point or points at the ...
  • I/A Series G3 Enterprise Network Server (ENS) learned proxy point does not properly inherit the maximum override duration fac...
  • WaynePeters
    WaynePeters
‎2018-09-06 12:27 PM
I/A Series G3 Enterprise Network Server (ENS) learned proxy point does not properly inherit the maximum override duration facet setting configured point or points at the ENC.
I/A Series G3 versions 3.5.xx and earlier
The mechanism within the core G3 software that controls the inheritance of the maxOverrideDuration facet for a learned proxy point was not added until 3.6.31.
Upgrade the I/A Series G3 Enterprise Network Server (ENS) and ENC to version 3.6.31 or higher.
  • TAC IA Series
  • 7744
