I/A Series G3 (AX) Lon Tunneling does not work in Windows 7
  • I/A Series G3 (AX) Lon Tunneling does not work in Windows 7
  • sesa116871
    sesa116871
‎2018-09-06 02:10 PM
The I/A Series G3 (AX) Lon Tunneling client does not work in Windows 7
  • G3 Version 3.5.25 and later
  • Windows 7 Professional OS
  • WPT 5.7.5 and later
The G3 Lon Tunnel client is written to run in Windows XP, and is not designed to run with native Windows 7.
  1. Ensure that the NiagaraAX Lon Tunnel Service is started (Control Panel > Administrative Tools > Services)
  2. Locate the vlonax.exe file in the C:\Windows\system32 directory. Right-click on the file, and select Properties
  3. In the Properties window, click the "Run this program in compatibility mode for:"  box, and select Windows XP (Service Pack 3) from the drop-down box.  Next, check the "Run this program as an administrator" check box
  4. Click OK to accept the changes
The Lon Tunnel client is now configured to work in Windows 7.
  • TAC IA Series
  • 4543
