Hyperlinks to a TGML page do not work in Webstation
  • Hyperlinks to a TGML page do not work in Webstation
  • sesa150561
    sesa150561
‎2018-09-06 09:15 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-26 06:58 AM
In Webstation, when clicking on a hyperlink located on a TGML that references another TGML, nothing happens.
Webstation
Sometimes when a graphic is saved, it gets compiled incorrectly. When this happens, the graphic will generally work inside Workstation because Workstation is a closed environment and much more forgiving then Webstation.
  1. Edit the graphic that you cannot open
  2. Save it again
  3. It will get recompiled correctly
  • 17144
