How to use the Piecewise command in Sigma Graphics.
Select a Country
  • How to use the Piecewise command in Sigma Graphics.
  • CraigEl
    CraigEl
  • RogerHa
    RogerHa
‎2018-09-06 12:36 PM
Last Updated: CraigEl Champion ‎2025-10-12 08:52 PM
When displaying a multi-value status from a programmable object in Sigma Graphics, updates may not reflect correctly unless the object value changes significantly (e.g., from 0 to 100). This can cause display issues when the graphic is open and the state changes.
Satchwell BAS & Sigma
Sigma Graphics Ver 4.0 onwards
Sigma Graphics does not automatically update the display unless the programmable object’s value changes in a way that triggers a refresh. This is problematic when using objects that return multiple discrete states.
Use the Piecewise command with stacked text objects to display the correct state visually.
Step-by-Step Workaround
  1. Create a Programmable Object
    Example logic:
    10 IF POINT 0|123 = 1.00000 THEN RETURN TRUE "Off"
    20 IF POINT 0|123 = 2.00000 THEN RETURN TRUE "Text No1"
    30 IF POINT 0|123 = 3.00000 THEN RETURN TRUE "Text No2"
    40 IF POINT 0|123 < 1.0 OR POINT 0|123 > 3.0 THEN RETURN "Invalid"
  2. Design the Graphic
    • Create three text objects:
      • 1 – Off
      • 2 – Text No1
      • 3 – Text No2
    • Stack them vertically with "Off" at the bottom.
    • Align them precisely over each other to form a single visual stack.
  3. Combine and Configure
    • Select all three text objects and combine them into one.
    • Assign a Piecewise command to the combined object:
      • Object: 123
      • Min: 1
      • Max: 3
  4. Behavior
    • The graphic will display the appropriate text based on the object’s value.
    • If the value is 0 or greater than 3, the display will be blank.
Notes
  • This method works best with analog values from programmable objects.
  • Variations are possible depending on the number of states and desired display behavior.
  • Satchwell BAS & Sigma
Tags (3)
  • 7452
  • CraigEllis25
  • minimum
