How to use Wiegand 26-Bit format cards in Security Expert with Custom Credentials
  • How to use Wiegand 26-Bit format cards in Security Expert with Custom Credentials
  • DavidChild
    DavidChild
  • David_Kendrick
    David_Kendrick
Admiral David_Kendrick Admiral
‎2021-07-21 08:17 AM
Last Updated: Sisko DavidChild Sisko ‎2021-07-21 08:19 AM
How to use Wiegand 26-Bit format cards in Security Expert with the new Custom Credentials
EcoStruxure Security Expert
  • Wiegand 26-Bit Format Access Cards
  • Custom Credentials
From the release of Security Expert 4.3, Custom Credentials have been introduced as a 'new' way of handling cards with formats such as Wiegand-26 Bit.
Select Sites > Credential Types and create a new Wiegand Credential Type called Wiegand 26-Bit with the following format:
A,FACILITY,8,MSB,BIN_B,CARD,16,MSB,BIN_PAAAAAAAABBBBBBBBBBBBBBBBP_EXXXXXXXXXXXX............._.............XXXXXXXXXXXXO
Select Programming > Door Types and create a new Door Type called Wiegand 26-Bit. Under Entry select a Reading Mode of Custom and then select 'Add'.Wie26 02.jpg
Select the Wiegand 26-Bit Credential Type created earlier.
If using Custom Credentials on both Entry and Exit this will need be done for both as shown below.Wie26 04.jpg
Select Programming > Doors and ensure the Door Type of the Door being configured is set to the Wiegand 26-Bit Door Type created earlier.
Select Expanders > Reader Expanders and ensure the Readers for the configured door are set to Custom Credential (Reader 1 Secondary format does not actually take effect and is set to Custom Credential here simply to avoid confusion).Wie26 06.jpg
Select Users > Users and create a test User.  Do not use the regular Card Numbers section which is filled out for cards which do NOT use the Custom Credential, and instead scroll down to the Credentials section at the very bottom of the General Tab.Wie26 07.jpg
Add the Wiegand 26-Bit Credential Type and Specify the users cards details in the format: Site Code : Card Number and then test.
  • EcoStruxure Security Expert
  • DavidKendrick21
