How to start an event sequence with a single click on a graphics page
  • How to start an event sequence with a single click on a graphics page
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 12:59 PM
I/NET 2.4x
Application Assistance
  1. Create and test an event sequence to carry out the function you wish to achieve
  2. Edit a graphics page
  3. Select I/NET>Tool Marker
  4. Choose label or graphic symbol as desired
  5. Next to the Tool Name field, click "Select"
  6. Click Add to create a new tool
  7. Name the tool
  8. Chose the event type
  9. Click OK
  10. Browse to the appropriate link
  11. Select the controller containing the event sequence created in step 1
  12. In the Available Events pane, select the Event Sequence created in step 1
  13. Click Add (if desired the tool can run multiple event sequences)
  14. Click OK till you are back to the graphics page
  15. Save and test.
  • TAC INET
  • 6759
