How to setup a BACnet MSTP Schneider Electric heat meter
  • How to setup a BACnet MSTP Schneider Electric heat meter
‎2018-09-11 06:23 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:46 AM
What configuration is required for a Multical BACnet heat meter
Schneider Electric (Kamstrup) heat meter connected to a Continuum or SmartStruxure system on MS/TP.
Multical 61/62/601/602/801
Setup information required
With the BACnet interface card fitted in the Multical meter it is a native BACnet MS/TP device.
Connect it to the AS or bCX1 depending on your system and Learn/ find BACnet devices. It should appear online and allow the objects to be uploaded.
A typical unit like the Multical 602 will contain 12 Analog Inputs for all of the information from the meter.
The Meter will operate at 9600, 19200, 38400, 57600 and 76800 Baud rates and autobaud to the connected system.
For the Datasheet  Click Here.
For the BACnet PICs statement Click Here.
For help with Heat meter selection see the online selection tool: Online Heat Meter Selection Tool - PA-00216
Labels (3)
  • Field Devices
  • 13167
