How to set the Network 8000 MicroZone II (MZ2) back to its factory-default settings?
  • How to set the Network 8000 MicroZone II (MZ2) back to its factory-default settings?
‎2018-09-10 06:32 AM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:06 AM
Need to set the Network 8000 MicroZone II (MZ2) back to its factory-default settings
See Technical Bulletin 95-08 for a detailed procedure.
Revised 12/22/2011
  • TAC IA Series
  • 6495
100% helpful (1/1)
