How to restore and view a Log backup (.LDB) without overwriting current database
  • How to restore and view a Log backup (.LDB) without overwriting current database
‎2018-09-06 02:18 PM
Last Updated: Crewman ContentModerator ‎2025-09-01 03:38 AM
  • How to restore and view a Log backup without overwriting current database
  • How to view backed-up events without overwriting current database
  • How to restore a SQL database  without overwriting current database
TAC Vista 4.3 and higher running a typical (not custom) SQL.
Warning
The event and logs will be backed up as a SQL backup file. This means that restoring a backup on the same PC that it was made on replaces the SQL database.
To view old data, restore the log database backup file on a different PC that has the same TAC Vista database on it.
  1. Create a copy of the TAC Vista database (or make a backup)
  2. Copy / restore the database to a computer that is running the same version of TAC Vista
  3. Go to the Server application and log in
  4. Go to File > Restore Log Database
  5. Browse in the backup file, the path should be filled in automatically
  • 4276
