How to remove a Security Level from Continuum
  • How to remove a Security Level from Continuum
  • PaulFr
    PaulFr
‎2018-09-06 01:20 PM
If a Security Level has been created in Cyberstation and is no longer required how can it be removed?
Cyberstation all versions
It may be required to remove a Security level from a system or to remove its action from an object.
It is not possible to delete a Security Level after it has been created in Cyberstation.
You can however remove the security level action from an object: in the Security Level tab; to de-select the security level right click and choose "Clear Selection".
  • 6095
