How to remove a Client PC from the I/NET Seven System
  • How to remove a Client PC from the I/NET Seven System
  • DavidChild
    DavidChild
  • sesa139513
    sesa139513
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 12:39 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-25 11:06 AM
How to properly remove a Client PC from the I/NET Seven System
TAC INET
I/NET Seven site
Steps to completely remove a Client PC from the I/NET Seven System
  1. Go into the IOServer Driver on the File Master PC
  2. Select the "Modify" for the active config.
  3. Look for the "Clients" Button in the middle of the window.
  4. Click on the "Clients" button, this open another window
  5. In the above window will list all of the clients in the Inet System. Since I only have one client in my system this is the way mine looks. Scroll down the list and highlight the PC you wish to remove from the File equalization list. You remove the PC by selecting the "Drop" button above. This will remove that PC from the File Masters list of PC to update.
  6. Go to the Actual PC you wish to remove.
  7. The go into that PC's IOServer Driver and Select the "Modify" button
  8. Demote the Client by either removing the File Masters computer name or its IP address in the "Filemaster name" box
  9. Following all these steps above will remove this PC's Name/IP from the list of PC to scan during the File Equalization process.
  • TAC INET
Tags (4)
  • 2505
  • ChrisAsbury19
  • DavidChild19
  • inet
