How to recover the password for Advanced Display version 3
  • How to recover the password for Advanced Display version 3
  • PeterEdvik
    PeterEdvik
  • Jonas_Brissman
    Jonas_Brissman
  • StephenYang
    StephenYang
Janeway Jonas_Brissman Janeway
‎2020-02-12 12:36 AM
Last Updated: Administrator CraigEl Administrator ‎2025-09-09 03:27 PM
What to do if the password for the Advanced Display v3 (AD v3) is lost or forgotten?
How is a factory reset done on an Advanced Display version 3 (AD v3)?
Building Operation Advanced Display V3
If the kiosk password for AD v3 is lost, there is no recovery option available. The only way to regain access is to perform a factory reset on the device.
To reset the AD v3 and set a new password, follow these steps:
  1. Power Cycle the Device
    • Press and hold the power button for at least 10 seconds until the device powers off.
  2. Initiate Factory Reset
    • Once the device restarts, tap the screen to bring up the reset options.
    • Highlight “Factory Reset” until it turns green.
    • The device will reboot with factory default settings.
  3. Reconfigure the Device
    • After reboot, select the SmartX HMI Kiosk app.
    • Enter your new desired password to complete setup.
The following video will guide you through the factory reset process on an AD v3:
Tags (2)
  • JonasBrissman20
  • StephenYang25
86% helpful (6/7)
