How to open a graphic panel from a Plain English program?
  • How to open a graphic panel from a Plain English program?
  • PaulFr
    PaulFr
‎2018-09-06 12:53 PM
A Graphic panel or other object needs to be opened by a Plain English program on Cyberstation, what command can be used?
Cyberstation Plain English Programs
It is often not clear what Plain English keyword can be used to open a Graphic Panel, or other object.
The "Show" command can be used to open a graphic from Plain English
For example:
Show AirHandler1
This will open a graphic called AirHandler1, enter Show in the online help search for further examples.
  • 6944
