How to mix match Half Duplex and Full Duplex devices on the same network?
  • How to mix match Half Duplex and Full Duplex devices on the same network?
  • StephenYang
    StephenYang
Admiral StephenYang Admiral
‎2023-12-12 03:40 PM
on ‎2023-12-12 03:40 PM
Erratic communication problems encountered during system migration from legacy products to AS-P controllers due to mismatched duplex settings.
EcoStruxure Building Operation.
  • SpaceLogic AS-P
  • SpaceLogic AS-B
Legacy controllers or existing devices supporting only Half-Duplex are incompatible with AS-P/AS-B controllers, which support Full Duplex 10/100BASE-TX communications.
To address this issue, follow these steps:
  1. Install a managed switch: Introduce a managed switch between the devices to enable effective communication.
  2. Configure port settings: Utilize the features of the managed switch to configure each port according to the required duplex mode, either Half-Duplex or Full-Duplex.
By implementing a managed switch, you can ensure compatibility between Half Duplex and Full Duplex devices, resolving communication problems and facilitating a smooth migration process.
  • StephenYang23
