How to make a report that shows all PIN assigned to Personnel objects in the system.
  • How to make a report that shows all PIN assigned to Personnel objects in the system.
  • AbeMeran
    AbeMeran
‎2018-09-06 12:48 PM
The PIN attribute of personnel objects has some limitations on visibility since it is considered sensitive information, this is the reason why Personnel PINs  do not show up in the personnel editor (it shows as ****) or List views.
CyberStation
Function as designed.
One way to generate a report that shows all personnel objects PIN is to create a CyberStation program that prints the PIN to a file (or some other print destination)
The following is a sample of a Looping CyberStation program that accomplishes the above.
Numeric CNT, OK
File NEWDATA
Object thePerson
OPENINGFILE:
  OK = OpenFile("C:\Temp\ALLPINS2.TXT", WriteOnly, NEWDATA)
  If OK = Failure then Goto ENDING Else Goto PRINTTOFILE
PRINTTOFILE:
  OpenList("Personnel", thePerson, Root)
  While GetObject(thePerson) is Success
    Print thePerson PIN to NEWDATA
  Endwhile
CloseList(thePerson)
  Goto CLOSINGFILE
CLOSINGFILE:
  OK = CloseFile(NEWDATA)
  If OK = Failure then Print "CANNOT CLOSE TEXT FILE" else goto ENDING
ENDING:
  Stop
  • 7117
