How to install hotfixes that replace executable files.
  • How to install hotfixes that replace executable files.
  • ScottLeedberg
    ScottLeedberg
  • sesa119747
    sesa119747
‎2018-09-06 02:31 PM
Continuum Cyberstation
No longer need the existing executable file and want to replace with the hotfix file.
The correct way to install a hotfix that replaces an executable file is to either delete the original file before installing the hotfix or to do the below.
  1. In Windows Explorer drag and drop copy the original file so you end up with a file called Copy of xxxxx.exe
  2. Delete the original file through Windows Explorer.
  3. Then extract the hotfix file into the Continuum directory through Windows Explorer.
Tags (2)
  • 3714
  • workstation
