How to install / add WebClient to existing SU installation of Continuum.
Continuum
WebClient
Warning
Existing Continuum SU Cyberstation installed and site is being upgraded with WebClient support.
Perform the following steps to install WebClient on your Single-User installation.
- Backup the ContinuumDB, Graphics files, and Menus to a safe location. (For detailed steps on how to backup / restore your ContinuumDB see here.)
- Upgrade security key to allow WebClient. (from supplied serialized upgrade code from Repairs)
- Uninstall Continuum.
- Install WebClient from scratch following the Planning and Installation Guide. (IIS then WebClient)
- Restore your ContinuumDB, graphics files and Menus.
- Test
