How to install Vista/Xenta Language packs
  • How to install Vista/Xenta Language packs
‎2018-09-10 01:39 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:45 AM
  • Vista Server
  • TAC Xenta Server
  • Vista Webstation
  • Vista Workstation
There are 4 different components that you can change the language on
  1. Vista server
  2. Vista workstation
  3. Vista webstation
  4. Xenta server's
The files you need for this can be downloaded on Extranet, if your preferable language does not exist it might be because they are not done with the translation for that current version or the language does not exist.
The most used one are
  • Danish
  • Finnish
  • German
  • Norwegian
  • Polish
  • Spanish
  • Swedish
The native language is English
NOTE: Remember, in order to download the correct version, the language pack needs to be same version as the current software installed.
There are 4 files that need to be downloaded and executed. The example below points to Swedish language pack files for version 5.1.6. To find the correct files search the download center for "Language Pack" as well as the desired language and version. The install order does not matter.
  1. TAC Vista Server 5.1.6 Language Pack Swedish
  2. TAC Vista Workstation 5.1.6 Language Pack Swedish
  3. TAC Web Applications 5.1.6 Language Pack Swedish
  4. TAC Xenta 700 5.1.6 Original Language Pack
The first three files are straight forward.  After the install is complete, the language files have been changed and you can run the software with the new language (Vista software should be installed prior installing the language pack).
The Xenta Server web interface will not change language until you download a project with the correct settings. When you do the download make sure you choose "Send all project and language files"  (see picture).
Note: For new Windows it sometimes require a multilingual file to be installed from Microsoft. Make sure the OS supports the language you want to install.
After that file has been installed, change the Language for non-unicode program to the preferred language (requires a restart of PC).
Tags (4)
  • 5568
  • JonasBrissman23
  • Peter Larsen 21
  • PeterLarsen21
