How to get alarms from more than one link to dial a pager
  • How to get alarms from more than one link to dial a pager
  • sesa139513
    sesa139513
‎2018-09-06 11:46 PM
I/NET Site
You could use indirect and global points to get the alarm conditions all into one link, then use 78061 to dial the pager. This is messy and bogs down lan traffic. A better solution is to connect a host pc to the host lan (or ethernet lan) and use the event printer port with Emergin software.
  • TAC INET
  • 1254
