How to filter a list view to only show certain entries?
  • How to filter a list view to only show certain entries?
  • PaulFr
    PaulFr
‎2018-09-06 12:41 PM
When opening one of the pre defined list views there are many entries and can not find text required.
List views
Filter, Qualifier, Query Wizard, Wildcard.
Default list views show all entries, how to define a qualifier to only show required data?
Create a new list view and define the Class and path, add in the required columns.
In the Qualifier tab select the "Query Wizard", for text comparisons use the required attribute e.g. Description, and "Is Like" as the Operator, enter the comparison text between wild card * characters (e.g. *Test* for the objects which contain the word Test) and it will filter only on objects whose attribute contain that text.
  • 7317
