How to enter command codes using a door keypad
  • How to enter command codes using a door keypad
  • AbeMeran
    AbeMeran
‎2018-09-10 04:58 AM
Using a door keypad to enter command codes to carry out commands such as arm/disarm system, extend door unlock on jet way etc.
CX9900 with AC1Plus
CX9680 with AC1Plus
ACX5720
ACX5740
Requirements
Click here for a PDF document with instructions on how to configure the system to capture command codes using a keypad at a door.
  • 6697
