How to display a photograph associated with a personnel record when a card is presented
  • How to display a photograph associated with a personnel record when a card is presented
  • PaulFr
    PaulFr
‎2018-09-06 01:24 PM
In Pinpoint, display the Photo of the person who has just swiped a card so it can be compared to a live image.
Continuum Cyberstation all versions
It is not clear how to dynamically update a Pinpoint graphic to show the last person entered
In Pinpoint Edit mode, from the Active Components menu select the "Personnel Picture" or select the “Active Personnel Picture” from the Active Components toolbar.
A Grey "Personnel Picture" box will appear on the page, this can be moved/ sized as required.
Animate this to the Door required and use the door attribute “LastPersonEntrd” this will update the photo on each card swipe.
If required you can define a fade delay time in seconds back to a default image.
Tags (2)
  • 5980
  • open
