How to determine which alarms are active in a controller when the Alarms system variable has a value > 0 but no alarms are shown in Cyberstation for that controller.
  • How to determine which alarms are active in a controller when the Alarms system variable has a value > 0 but no alarms are...
  • sesa119747
    sesa119747
  • AbeMeran
    AbeMeran
‎2018-09-06 01:05 PM
The Alarms system variable in a controller contains a value other than zero but Active Alarm list view in CyberStation does not show any active alarms from that controller, How can I find out which alarms are active in the controller?
CyberStation
All CXs
All I2 devices
Active alarm can be determined by creating a column in the default list view to store alarm information from 'Live' source.
  1. Right click on InfinityNumeric and select 'View' to launch the default list view for the class.
  2. Edit the list view and add a column for the 'AlarmValue' attribute and set the column source to 'Live'
  3. Run the list view and inspect the AlarmValue:
    Blank = No active alarm on point
    Alm1 = the first alarm is active on point.
    Alm2 = the second alarm is active on point
    Alm8 = the 8th alarm is active on the point
  • 6582
