How to determine the Hexadecimal number of a prox card
  • How to determine the Hexadecimal number of a prox card
  • sesa139513
    sesa139513
  • Tom_Poovey
    Tom_Poovey
‎2018-09-07 01:21 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-25 10:48 AM
Is there a way in I/NET Seven to determine the Hexadecimal number of a prox card?
TAC INET
I/NET site with Access Control
Determining the Hexadecimal number of a prox card
  1. Go into AMT and select "System" on the top task Bar. Choose the highlighted options.
  2. All you have to do in this window is the hit the "OK" button. This will set up an AMT screen called "No Filter"
  3. If the card you are seeking the Hex number IS NOT in the Individuals editor, and you read that card at any system reader it will give you the Hex number on the card under the “Message” area.
The only other choice in getting this information is thru a RS232 device like the ones sold on RfIdeas.com.
  • TAC INET
  • 2499
