How to create a local String Variable in a Xenta 731.
  • How to create a local String Variable in a Xenta 731.
  • sesa150555
    sesa150555
‎2018-09-06 01:14 PM
Data Type String is not allowed in this node. When trying to set data type to string.
TAC Xbuilder
The datatype string can only be used for SNVT str_asc and signals connected to SNVTs of this type.
To get a String signal you have to use snvt_str_asc.
  • 6287
